Ga door naar hoofdinhoud
Lasko 4910 Filter Replacement
Wat je nodig hebt
  1. Lasko 4910 Filter Replacement, Filter: stap 1, afbeelding 1 van 1
    • On the backside of the fan, remove the top two 4mm Phillips #Y1 screws using PH 1 bit and Magnetic Driver
  2. Lasko 4910 Filter Replacement: stap 2, afbeelding 1 van 1
    • Remove the top plastic portion of the fan
  3. Lasko 4910 Filter Replacement: stap 3, afbeelding 1 van 1
    • Remove all four 4mm screws using the Phillips #1 screwdriver.
  4. Lasko 4910 Filter Replacement: stap 4, afbeelding 1 van 1
    • Remove the filter from the fan.
Conclusie
Julie Ling
159 Reputatie
1 Handleiding geschreven
UC Davis, Team S11-G2, Lore Fall 2018 Lid van UC Davis, Team S11-G2, Lore Fall 2018
UCD-LORE-F18S11G2
4 Leden
1 handleiding geschreven
Één opmerking
Thank you for taking the time to do this. A great little guide for a fan that doesn't have a lot of support. Most details are looked over in online guide material. But this one was done with professional care.
Sincerely,
Davis Steffens
Seattle, WA
davissteffens@hotmail.com
PS: I Fix-It represents more than a company providing a service. I think you are reminding everyone that we have the right to Fix. Which in these weird times is a step needed.
Davis Steffens - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,715
