Ga door naar hoofdinhoud
Lamp Switch Replacement
Wat je nodig hebt
  1. Lamp Switch Replacement, Switch: stap 1, afbeelding 1 van 1
    • Unplug the lamp from the wall to reduce the risk of electric shock.
    Vraag FixBot
    Voeg opmerking toe
  2. Lamp Switch Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the light bulb from the socket then remove the lamp shade.
    Vraag FixBot
    Voeg opmerking toe
  3. Lamp Switch Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws from the bottom inside the socket. These screws hold the silver threaded socket in place.
    Vraag FixBot
    Voeg opmerking toe
  4. Lamp Switch Replacement: stap 4, afbeelding 1 van 1
    • When the screws are removed, the threaded socket will pull out.
    Vraag FixBot
    Voeg opmerking toe
  5. Lamp Switch Replacement: stap 5, afbeelding 1 van 1
    • Unscrew and remove the outer black socket body.
    Vraag FixBot
    Voeg opmerking toe
  6. Lamp Switch Replacement: stap 6, afbeelding 1 van 1
    • Partially peel back the felt or cork from bottom of the lamp to gain access to power cord. Take care to avoid tearing.
    Vraag FixBot
    Voeg opmerking toe
  7. Lamp Switch Replacement: stap 7, afbeelding 1 van 1
    • Push a few inches of the power cord upwards to gain slack to work with. Some cords may have a knot tied here which will need loosened to push slack upwards.
    Vraag FixBot
    Voeg opmerking toe
  8. Lamp Switch Replacement: stap 8, afbeelding 1 van 1
    • Pull the socket base/switch assembly out of the base to gain access to the screw terminals on the sides.
    Vraag FixBot
    Voeg opmerking toe
  9. Lamp Switch Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the terminals on each side to release the wires. The screws may be retained so they may not come all the way out.
    Vraag FixBot
    Voeg opmerking toe
  10. Lamp Switch Replacement: stap 10, afbeelding 1 van 1
    • Attach the wires to the new switch assembly. It doesn't matter which wire goes to which terminal. For a secure connection, bend a hook into the end of the wire and orient it on the screw so the hook closes when the screw is tightened.
    Vraag FixBot
    Voeg opmerking toe
  11. Lamp Switch Replacement: stap 11, afbeelding 1 van 1
    • Position the socket/switch assembly on the base and pull the power cord from the bottom to set the socket in place. Reattach the felt or cork on the bottom of the lamp.
    Vraag FixBot
    Voeg opmerking toe
  12. Lamp Switch Replacement: stap 12, afbeelding 1 van 1
    • Pushing downward to hold the socket in place, screw the black outer socket back in place to secure the switch.
    Vraag FixBot
    Voeg opmerking toe
  13. Lamp Switch Replacement: stap 13, afbeelding 1 van 1
    • Set the sliver threaded socket into place. Turn the socket to align the two screw holes.
    Vraag FixBot
    Voeg opmerking toe
  14. Lamp Switch Replacement: stap 14, afbeelding 1 van 1
    • Screw in the two screws to secure the threaded silver socket into place.
    Vraag FixBot
    Voeg opmerking toe
  15. Lamp Switch Replacement: stap 15, afbeelding 1 van 1
    • Reattach the lamp shade and screw in the light bulb.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
After following these steps to replace a non-working switch, you should again have a functional lamp.
10 andere personen hebben deze handleiding voltooid.
Matt Plueger
363 Reputatie
1 Handleiding geschreven
2Gids Commentaar
A very nice and clear explanation. Unfortunately the pull chain switch in my lap was riveted to the socket so I had to replace the entire socket. It really was easy though and required less steps than your switch replacement. Here’s a video that shows exactly what I did: https://youtu.be/0fLnUPWzLeI
Thanks!
Scott Clark - Antwoord Deel
WOW! I almost threw away my fav Lil lamp - vacuuming I tipped over the lamp and it cracked the threaded plastic part - I followed your instructions and now have a nonflickering - fully functioning lamp! Thanks perfect timing
anggnbama - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 94
Altijd: 14,718
