Ga door naar hoofdinhoud
LaCie Rugged USB-C Hard Drive Replacement
Wat je nodig hebt
  1. LaCie Rugged USB-C Hard Drive Replacement, Overview: stap 1, afbeelding 1 van 3 LaCie Rugged USB-C Hard Drive Replacement, Overview: stap 1, afbeelding 2 van 3 LaCie Rugged USB-C Hard Drive Replacement, Overview: stap 1, afbeelding 3 van 3
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: stap 2, afbeelding 1 van 2 LaCie Rugged USB-C Hard Drive Replacement, Case Removal: stap 2, afbeelding 2 van 2
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Hard Drive Replacement, Case Screws: stap 3, afbeelding 1 van 2 LaCie Rugged USB-C Hard Drive Replacement, Case Screws: stap 3, afbeelding 2 van 2
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: stap 4, afbeelding 1 van 2 LaCie Rugged USB-C Hard Drive Replacement, Case Removal: stap 4, afbeelding 2 van 2
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: stap 5, afbeelding 1 van 2 LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: stap 5, afbeelding 2 van 2
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Hard Drive Replacement, Drive Removal: stap 6, afbeelding 1 van 1
    • Pull the drive gently out of the SATA connector.
Conclusie
6 andere personen hebben deze handleiding voltooid.
9021007
4.599 Reputatie
25 handleidingen geschreven
4 opmerkingen
Thanks for confirming the T8 Torx security bit - I had to buy a set!
Andy Gibbons - Antwoord
Andy, how are you. ?
Am facing the same issue, did fixed yours ?
Dion Diogo Mar -
Hello, I have this same drive. My hard drive is fine, the internal case that has the SATA to USB C connector isn’t working. Is there a replacement for the adapter/inner case & the adapter?
James Causey - Antwoord
I have no idea of replacement of the LaCie internal case
But any generic USB C To SATA Adapter can be used - and very cheap on amazon too
Like in this link for example
Eoin -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 114
Altijd: 4,502
