Ga door naar hoofdinhoud
LaCie Rugged USB-C Circuit Board Replacement
Wat je nodig hebt
  1. LaCie Rugged USB-C Circuit Board Replacement, Overview: stap 1, afbeelding 1 van 3 LaCie Rugged USB-C Circuit Board Replacement, Overview: stap 1, afbeelding 2 van 3 LaCie Rugged USB-C Circuit Board Replacement, Overview: stap 1, afbeelding 3 van 3
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: stap 2, afbeelding 1 van 2 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: stap 2, afbeelding 2 van 2
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Circuit Board Replacement, Case Screws: stap 3, afbeelding 1 van 2 LaCie Rugged USB-C Circuit Board Replacement, Case Screws: stap 3, afbeelding 2 van 2
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: stap 4, afbeelding 1 van 2 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: stap 4, afbeelding 2 van 2
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: stap 5, afbeelding 1 van 2 LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: stap 5, afbeelding 2 van 2
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Circuit Board Replacement, Drive Removal: stap 6, afbeelding 1 van 1
    • Pull the drive gently out of the SATA connector.
  7. LaCie Rugged USB-C Circuit Board Replacement, Screw Removal: stap 7, afbeelding 1 van 1
    • Remove this Phillips 00 screw from the board.
  8. LaCie Rugged USB-C Circuit Board Replacement, Board Removal: stap 8, afbeelding 1 van 1
    • Slide the board out, making sure to keep any foam pieces intact.
    • Do not let any foam pieces get damaged. They are important.
Conclusie
5 andere personen hebben deze handleiding voltooid.
9021007
4.599 Reputatie
25 handleidingen geschreven
3 opmerkingen
Where can i get a new board? thank you
Bar Avraham - Antwoord
Yes, where can we find a new board?
Vassilis Trigkas - Antwoord
Right, where can the part be purchased?????
James Causey - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 65
Altijd: 1,553
