Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two plastic screw covers below the inside phone screen.
Pry off the screen front cover with a 3mm flathead screwdriver.
Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver.
Unsolder the black and red wires of the speaker from where they are attached to the base of the screen.
Obtain replacement speaker and solder the new black and red wires back to the base of the screen.
Apply glue to the back of the speaker and place it back in its original position.
Één andere persoon heeft deze handleiding voltooid.
