Inleiding
In this guide, you will see how to take apart the LG-A275 in order to replace the phone's speaker.
Wat je nodig hebt
Stap 1 Battery
Voorzichtig: stappen 1-3 komen van een handleiding die in bewerking is.
Turn the phone upside down so that the bottom of the back is facing you.
Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
