Ga door naar hoofdinhoud
LG env2 vx9100 Side Buttons Replacement
Wat je nodig hebt
  1. LG env2 vx9100 Side Buttons Replacement, Battery: stap 1, afbeelding 1 van 3 LG env2 vx9100 Side Buttons Replacement, Battery: stap 1, afbeelding 2 van 3 LG env2 vx9100 Side Buttons Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Side Buttons Replacement, Back Panel: stap 2, afbeelding 1 van 2 LG env2 vx9100 Side Buttons Replacement, Back Panel: stap 2, afbeelding 2 van 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Side Buttons Replacement: stap 3, afbeelding 1 van 2 LG env2 vx9100 Side Buttons Replacement: stap 3, afbeelding 2 van 2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Side Buttons Replacement: stap 4, afbeelding 1 van 2 LG env2 vx9100 Side Buttons Replacement: stap 4, afbeelding 2 van 2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Side Buttons Replacement, Side Buttons: stap 5, afbeelding 1 van 2 LG env2 vx9100 Side Buttons Replacement, Side Buttons: stap 5, afbeelding 2 van 2
    • Locate the volume and camera buttons on the right side of the phone.
    • Lift up on the buttons to slide them out of the phone.
Conclusie
Reed Williston
34 Reputatie
7 handleidingen geschreven
Cal Poly, Team 16-55, Forte Fall 2012 Lid van Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 13
Altijd: 488
