Inleiding
In this guide you will be removing the back panel to access the motherboard. Once you have reached the motherboard you will remove the camera lens from the motherboard.
Wat je nodig hebt
Place the phone face down on the table.
Pull down the tab below the battery with your fingernail or an opening tool.
Lift the battery out.
Locate the five rubber covers on the back panel of the phone.
Use a metal probe to remove each rubber cover and expose the screws underneath.
Locate the ribbon attached to the lens of the camera.
Place the plastic opening tool in between the logic board and ribbon.
Lift up the plastic opening to detach the ribbon from the logic board.
Één andere persoon heeft deze handleiding voltooid.
