Ga door naar hoofdinhoud
LG Xenon Speaker Replacement
Wat je nodig hebt
  1. LG Xenon Speaker Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Turn the phone so the back side is face up.
  2. LG Xenon Speaker Replacement: stap 2, afbeelding 1 van 2 LG Xenon Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
  3. LG Xenon Speaker Replacement, Battery: stap 3, afbeelding 1 van 2 LG Xenon Speaker Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
  4. LG Xenon Speaker Replacement, Motherboard: stap 4, afbeelding 1 van 2 LG Xenon Speaker Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
  5. LG Xenon Speaker Replacement: stap 5, afbeelding 1 van 1
    • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
  6. LG Xenon Speaker Replacement: stap 6, afbeelding 1 van 2 LG Xenon Speaker Replacement: stap 6, afbeelding 2 van 2
    • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
  7. LG Xenon Speaker Replacement: stap 7, afbeelding 1 van 2 LG Xenon Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
  8. LG Xenon Speaker Replacement: stap 8, afbeelding 1 van 2 LG Xenon Speaker Replacement: stap 8, afbeelding 2 van 2
    • Carefully lift and remove the motherboard from the main body.
    • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
  9. LG Xenon Speaker Replacement: stap 9, afbeelding 1 van 2 LG Xenon Speaker Replacement: stap 9, afbeelding 2 van 2
    • Carefully unclip the metal tab to separate the connector cable from the motherboard.
  10. LG Xenon Speaker Replacement: stap 10, afbeelding 1 van 2 LG Xenon Speaker Replacement: stap 10, afbeelding 2 van 2
    • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
  11. LG Xenon Speaker Replacement, Keyboard: stap 11, afbeelding 1 van 1
    • Turn the motherboard over and carefully remove the keypad from the motherboard.
    • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
  12. LG Xenon Speaker Replacement, LCD: stap 12, afbeelding 1 van 1
    • After removing the motherboard and keyboard, unscrew eight 1.6mm Phillips #00 screws in the middle of the phone.
  13. LG Xenon Speaker Replacement: stap 13, afbeelding 1 van 1
    • Remove slider piece.
    • Pay close attention that you don’t lose the spring.
    • Carefully remove the spring.
  14. LG Xenon Speaker Replacement: stap 14, afbeelding 1 van 2 LG Xenon Speaker Replacement: stap 14, afbeelding 2 van 2
    • Remove six 2.25mm Phillips #00 screws along the outside of the case.
  15. LG Xenon Speaker Replacement: stap 15, afbeelding 1 van 2 LG Xenon Speaker Replacement: stap 15, afbeelding 2 van 2
    • Using the plastic opening tool, carefully open and remove the case. Slide the tool along the edge and pry upwards to open.
  16. LG Xenon Speaker Replacement: stap 16, afbeelding 1 van 1
    • Remove the black electrical tape holding the LCD to the screen.
  17. LG Xenon Speaker Replacement: stap 17, afbeelding 1 van 1
    • Un-clasp the small tab in the top right corner.
  18. LG Xenon Speaker Replacement: stap 18, afbeelding 1 van 3 LG Xenon Speaker Replacement: stap 18, afbeelding 2 van 3 LG Xenon Speaker Replacement: stap 18, afbeelding 3 van 3
    • Unhook the LCD from tabs on the bottom using the plastic opening tool.
    • Remove the LCD. Be careful, the LCD screen is fragile.
  19. LG Xenon Speaker Replacement, Speaker: stap 19, afbeelding 1 van 2 LG Xenon Speaker Replacement, Speaker: stap 19, afbeelding 2 van 2
    • The speaker is attached to the top of the LCD.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Micaela Saqui
78 Reputatie
7 handleidingen geschreven
Cal Poly, Team 9-41, Regan Spring 2012 Lid van Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 879
