Inleiding
The keyboard is placed on the motherboard but is not attached in any way. This step is easy because there are no necessary tools involved. It is a simple and easy step that allows you to clean the keyboard.
Wat je nodig hebt
Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
Turn the motherboard over and carefully remove the keypad from the motherboard.
The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
Één andere persoon heeft deze handleiding voltooid.
