Ga door naar hoofdinhoud
LG X Style Speaker Replacement
Wat je nodig hebt
  1. LG X Style Speaker  Replacement, Screen: stap 1, afbeelding 1 van 2 LG X Style Speaker  Replacement, Screen: stap 1, afbeelding 2 van 2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  2. LG X Style Speaker  Replacement: stap 2, afbeelding 1 van 3 LG X Style Speaker  Replacement: stap 2, afbeelding 2 van 3 LG X Style Speaker  Replacement: stap 2, afbeelding 3 van 3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  3. LG X Style Speaker  Replacement, Battery: stap 3, afbeelding 1 van 1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  4. LG X Style Speaker  Replacement: stap 4, afbeelding 1 van 2 LG X Style Speaker  Replacement: stap 4, afbeelding 2 van 2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  5. LG X Style Speaker  Replacement, Speaker: stap 5, afbeelding 1 van 3 LG X Style Speaker  Replacement, Speaker: stap 5, afbeelding 2 van 3 LG X Style Speaker  Replacement, Speaker: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool into slit around speaker box on mid shield frame.
    • Gently pop up the speaker housing.
    • If the adhesive film doesn’t remove itself with the speaker housing, use the plastic opening tool to remove film.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 339
