Ga door naar hoofdinhoud
LG Watch Urbane Screen Replacement
Wat je nodig hebt
  1. LG Watch Urbane Screen Replacement, Battery: stap 1, afbeelding 1 van 2 LG Watch Urbane Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Screen Replacement: stap 2, afbeelding 1 van 2 LG Watch Urbane Screen Replacement: stap 2, afbeelding 2 van 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Screen Replacement: stap 3, afbeelding 1 van 3 LG Watch Urbane Screen Replacement: stap 3, afbeelding 2 van 3 LG Watch Urbane Screen Replacement: stap 3, afbeelding 3 van 3
    Magnetic Project Mat
    $19.95
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Screen Replacement: stap 4, afbeelding 1 van 3 LG Watch Urbane Screen Replacement: stap 4, afbeelding 2 van 3 LG Watch Urbane Screen Replacement: stap 4, afbeelding 3 van 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
  5. LG Watch Urbane Screen Replacement, Screen: stap 5, afbeelding 1 van 2 LG Watch Urbane Screen Replacement, Screen: stap 5, afbeelding 2 van 2
    $19.95
    • Now that you have removed the motherboard and battery, it is time to remove the dock connector.
    • Using a PH000 screwdriver, remove the two screws in order to release the dock connector from the watch.
    • Do not lose the two screws! Keep them somewhere you will remember! A magnetic mat can help with this. iFixit Magnetic Mat
  6. LG Watch Urbane Screen Replacement: stap 6, afbeelding 1 van 2 LG Watch Urbane Screen Replacement: stap 6, afbeelding 2 van 2
    • Once the screws are removed, the dock connector is free to be moved.
    • Gently lift the dock connector away from the frame and you will now be able to see the screen.
    • The watch's screen is stuck to the back of the glass with an adhesive so be tedious when pulling it off.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Luis Guinand
151 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-4, Remmell Fall 2015 Lid van USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 Leden
5 handleidingen geschreven
2Gids Commentaar
where i can find watch urbane display ?
melancholie - Antwoord
Does anyone know where to buy the display?
James Elmore - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 2,611
