Inleiding
In order to replace your motherboard you are going to need the proper tools. There are screws that need to be unscrewed and components that need to be pried open carefully. The tools needed will be plastic opening tools, PH #000 screwdriver and tweezers. With these prepared everything should be ready to start the replacement of the motherboard for the LG Watch Urbane.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$4.99
Push on the band in order to expose the pins
Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
3 andere personen hebben deze handleiding voltooid.
