Ga door naar hoofdinhoud
LG Watch Urbane Battery Replacement
Wat je nodig hebt
  1. LG Watch Urbane Battery Replacement, Battery: stap 1, afbeelding 1 van 2 LG Watch Urbane Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Replacement: stap 2, afbeelding 1 van 2 LG Watch Urbane Battery Replacement: stap 2, afbeelding 2 van 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Replacement: stap 3, afbeelding 1 van 3 LG Watch Urbane Battery Replacement: stap 3, afbeelding 2 van 3 LG Watch Urbane Battery Replacement: stap 3, afbeelding 3 van 3
    Magnetic Project Mat
    $19.95
    Koop
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Replacement: stap 4, afbeelding 1 van 3 LG Watch Urbane Battery Replacement: stap 4, afbeelding 2 van 3 LG Watch Urbane Battery Replacement: stap 4, afbeelding 3 van 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
Conclusie
18 andere personen hebben deze handleiding voltooid.
Rey Diaz
699 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-4, Remmell Fall 2015 Lid van USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 Leden
4 handleidingen geschreven
11 opmerkingen
"pried" not "pryed"
Patty Remmell - Antwoord
Where do I find a replacement battery?
nickpfau - Antwoord
Found mine on ebay. Search for BL-S3 battery.
Atreidae -
The reassembly requires gluing the back together. How do you get the glue?
jiteshshahin - Antwoord
There is glue around cover. I suppose when closing we should add glue to be waterproof again? Nothing about it in the guide, beside that ok.
Imx - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 15,468
