Ga door naar hoofdinhoud
LG Watch Urbane Battery Case Replacement
Wat je nodig hebt
  1. LG Watch Urbane Battery Case  Replacement, Battery: stap 1, afbeelding 1 van 2 LG Watch Urbane Battery Case  Replacement, Battery: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Case  Replacement: stap 2, afbeelding 1 van 2 LG Watch Urbane Battery Case  Replacement: stap 2, afbeelding 2 van 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Case  Replacement: stap 3, afbeelding 1 van 3 LG Watch Urbane Battery Case  Replacement: stap 3, afbeelding 2 van 3 LG Watch Urbane Battery Case  Replacement: stap 3, afbeelding 3 van 3
    Magnetic Project Mat
    $19.95
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Case  Replacement: stap 4, afbeelding 1 van 3 LG Watch Urbane Battery Case  Replacement: stap 4, afbeelding 2 van 3 LG Watch Urbane Battery Case  Replacement: stap 4, afbeelding 3 van 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
  5. LG Watch Urbane Battery Case  Replacement, Battery Case: stap 5, afbeelding 1 van 2 LG Watch Urbane Battery Case  Replacement, Battery Case: stap 5, afbeelding 2 van 2
    • Use the PH000 screwdriver to remove the two highlighted screws to release the battery
  6. LG Watch Urbane Battery Case  Replacement: stap 6, afbeelding 1 van 1
    • Carefully pinch out the battery case with your fingers to remove it from the face of the watch.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Philip Sears
195 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-4, Remmell Fall 2015 Lid van USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 Leden
5 handleidingen geschreven
1Gids Commentaar
Where to buy a battery to replacement
sdptuananh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 1,253
