Inleiding
This guide will show you how to disassemble the LG Vu CU920 to replace a broken charging/headphone port. You will need to keep track of small screws, remove small components from the motherboard, and solder/unsolder a component
Wat je nodig hebt
Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
Remove the two 3.5 mm screws above the battery port with a Phillips #00 screwdriver.
Unsolder the charging port located on the left side of the motherboard.
Solder in a replacement charging port.
Één andere persoon heeft deze handleiding voltooid.
