Turn over the phone so the front screen is facing down and the back side is up.
  • Turn over the phone so the front screen is facing down and the back side is up.
Voeg opmerking toe
Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
Voeg opmerking toe
To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
  • Then press down on the bottom of the battery and it should snap into place
Voeg opmerking toe
Conclusie
Michelle
17 Reputatie
3 handleidingen geschreven
Cal Poly, Team 17-26, Amido Spring 2012 Lid van Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 259
