Ga door naar hoofdinhoud
LG Voyager Antenna Replacement
Wat je nodig hebt
  1. LG Voyager Antenna Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn over the phone so the front screen is facing down and the back side is up.
  2. LG Voyager Antenna Replacement: stap 2, afbeelding 1 van 1
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  3. LG Voyager Antenna Replacement: stap 3, afbeelding 1 van 1
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
  4. LG Voyager Antenna Replacement, Antenna: stap 4, afbeelding 1 van 1
    • First remove the battery by pulling the tab away from the device
    • Next remove the 5 rubber modules by gently prying underneath them. This will expose the screws underneath
  5. LG Voyager Antenna Replacement: stap 5, afbeelding 1 van 2 LG Voyager Antenna Replacement: stap 5, afbeelding 2 van 2
    • Next remove the 6 #00 Phillips screws holding the back in place
    • screws: 1.43mm head, 3.61mm length
  6. LG Voyager Antenna Replacement: stap 6, afbeelding 1 van 3 LG Voyager Antenna Replacement: stap 6, afbeelding 2 van 3 LG Voyager Antenna Replacement: stap 6, afbeelding 3 van 3
    • Now, slide a plastic opening tool in between the two plastic pieces that form the outside of the back case
    • Gently work the plastic opening tool around the edge of the case to separate the two pieces
    • Once the case has been separated you should be able to see the circuitry inside the phone
  7. LG Voyager Antenna Replacement: stap 7, afbeelding 1 van 3 LG Voyager Antenna Replacement: stap 7, afbeelding 2 van 3 LG Voyager Antenna Replacement: stap 7, afbeelding 3 van 3
    • Remove the #00 Philips screw holding the antenna in place
    • Screw: 4.52mm length, 2.68mm head
    • Once the screw is removed, lift the small case around the antenna off
  8. LG Voyager Antenna Replacement: stap 8, afbeelding 1 van 2 LG Voyager Antenna Replacement: stap 8, afbeelding 2 van 2
    • Now that you have the antenna exposed, you can remove it
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Paul Heckler II
40 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-26, Amido Spring 2012 Lid van Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 321
