Ga door naar hoofdinhoud
LG VX9800 Front Keypad Replacement
Wat je nodig hebt
  1. LG VX9800 Front Keypad Replacement, Front Keypad: stap 1, afbeelding 1 van 1
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 Front Keypad Replacement: stap 2, afbeelding 1 van 1
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 Front Keypad Replacement: stap 3, afbeelding 1 van 1
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 Front Keypad Replacement: stap 4, afbeelding 1 van 1
    • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 Front Keypad Replacement: stap 5, afbeelding 1 van 2 LG VX9800 Front Keypad Replacement: stap 5, afbeelding 2 van 2
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  6. LG VX9800 Front Keypad Replacement: stap 6, afbeelding 1 van 3 LG VX9800 Front Keypad Replacement: stap 6, afbeelding 2 van 3 LG VX9800 Front Keypad Replacement: stap 6, afbeelding 3 van 3
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 Front Keypad Replacement: stap 7, afbeelding 1 van 1
    • The faceplate and keypad can now be completely removed from the phone.
Eindstreep
Aaron Rowley
33 Reputatie
2 handleidingen geschreven
Cal Poly, Team 16-32, Maness Winter 2010 Lid van Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 1,897
