Wat je nodig hebt
Slide the back cover off using the release latch with your fingers to expose the battery.
Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
First, pull back the tape covering the connection between the motherboard and the ribbon cable.
Separate the connection, using the plastic opening tool.
