Ga door naar hoofdinhoud
LG VX8700 Keypad Replacement
Wat je nodig hebt
  1. LG VX8700 Keypad Replacement, Battery: stap 1, afbeelding 1 van 2 LG VX8700 Keypad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Keypad Replacement: stap 2, afbeelding 1 van 2 LG VX8700 Keypad Replacement: stap 2, afbeelding 2 van 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Keypad Replacement, Keypad: stap 3, afbeelding 1 van 2 LG VX8700 Keypad Replacement, Keypad: stap 3, afbeelding 2 van 2
    • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
  4. LG VX8700 Keypad Replacement: stap 4, afbeelding 1 van 2 LG VX8700 Keypad Replacement: stap 4, afbeelding 2 van 2
    • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
    • Slide the opening tool along the seam and around the edge of the phone to separate the case.
  5. LG VX8700 Keypad Replacement: stap 5, afbeelding 1 van 1
    • Separate the two halves of the phone.
    • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
    • The plastic casing is displayed on the right.
  6. LG VX8700 Keypad Replacement: stap 6, afbeelding 1 van 3 LG VX8700 Keypad Replacement: stap 6, afbeelding 2 van 3 LG VX8700 Keypad Replacement: stap 6, afbeelding 3 van 3
    • Hold the phone casing with one hand and the keypad assembly with the other.
    • Separate the phone casing from the keypad/motherboard.
  7. LG VX8700 Keypad Replacement: stap 7, afbeelding 1 van 2 LG VX8700 Keypad Replacement: stap 7, afbeelding 2 van 2
    • Pull the two boards apart to separate the keypad from the motherboard.
Conclusie
tnscholz
18 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-16, Maness Winter 2012 Lid van Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Leden
14 handleidingen geschreven
Één opmerking
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
gfon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 724
