Ga door naar hoofdinhoud
LG VX8700 Front Bezel Replacement
Wat je nodig hebt
  1. LG VX8700 Front Bezel Replacement, Battery: stap 1, afbeelding 1 van 2 LG VX8700 Front Bezel Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Front Bezel Replacement: stap 2, afbeelding 1 van 2 LG VX8700 Front Bezel Replacement: stap 2, afbeelding 2 van 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Front Bezel Replacement, Front Bezel: stap 3, afbeelding 1 van 1
    • Turn your phone around and open the flip phone.
    • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
    • Remove the two grey screw-covers at the bottom of the screen
  4. LG VX8700 Front Bezel Replacement: stap 4, afbeelding 1 van 2 LG VX8700 Front Bezel Replacement: stap 4, afbeelding 2 van 2
    • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
    • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
  5. LG VX8700 Front Bezel Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  6. LG VX8700 Front Bezel Replacement: stap 6, afbeelding 1 van 2 LG VX8700 Front Bezel Replacement: stap 6, afbeelding 2 van 2
    • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Carefully open the cover.
Conclusie
Stanley Thomas
41 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-16, Maness Winter 2012 Lid van Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 989
