Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Turn the phone off. Remove the back cover by sliding the tab away from the phone using one finger.
    • Turn the phone off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. Lift one side of the battery using a plastic opening tool or your fingers.
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
  3. When installing the battery, make sure to align the metal pins with those of the phone.
    • When installing the battery, make sure to align the metal pins with those of the phone.
Conclusie
Andrew
7 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-16, Maness Winter 2012 Lid van Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Leden
14 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 734
