Ga door naar hoofdinhoud
Inleiding
Steps to replace the LG VX8550 motherboard
  1. Slide the battery release up.
    • Slide the battery release up.
  2. Remove the battery by lifting away from the case.
    • Remove the battery by lifting away from the case.
  3. Remove the 2 screw covers next to the rear speaker with a Push Pin.
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. Remove the 4 cover screws with a Philips #00 screwdriver.
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Nu winkelen
    iPhone X Fix Kits
    Nu winkelen
  6. Use the iPod opening tool to pry off the back casing.
    • Use the iPod opening tool to pry off the back casing.
  7. Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  8. Separate the casing halves.
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  9. Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  10. Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  11. Remove the motherboard from the front casing by lifting straight up.
    • Remove the motherboard from the front casing by lifting straight up.
Conclusie
Nathan Jones
83 Reputatie
10 handleidingen geschreven
Cal Poly, Team 34-55, Forte Spring 2010 Lid van Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Leden
20 handleidingen geschreven
Één commentaar
It is a nice way to remove the motherboard of the LG mobile i did not done it but your have done it very nicely and with a great way. thanks for this good post i really enjoy the reading.
http://harrypotter1081.livejournal.com/
Harry Potter - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 2,391
