Ga door naar hoofdinhoud
LG VX8550 Keypad Housing Replacement
Wat je nodig hebt
  1. LG VX8550 Keypad Housing Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery release up.
  2. LG VX8550 Keypad Housing Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Keypad Housing Replacement, Case: stap 3, afbeelding 1 van 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Keypad Housing Replacement: stap 4, afbeelding 1 van 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Keypad Housing Replacement: stap 5, afbeelding 1 van 1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Keypad Housing Replacement: stap 6, afbeelding 1 van 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Keypad Housing Replacement: stap 7, afbeelding 1 van 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Keypad Housing Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Keypad Housing Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Keypad Housing Replacement: stap 10, afbeelding 1 van 1
    • Remove the motherboard from the front casing by lifting straight up.
  11. LG VX8550 Keypad Housing Replacement, Keypad Housing: stap 11, afbeelding 1 van 1
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. LG VX8550 Keypad Housing Replacement: stap 12, afbeelding 1 van 1
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. LG VX8550 Keypad Housing Replacement: stap 13, afbeelding 1 van 1
    • Lift the keypad housing away from the slider.
Conclusie
Nathan Jones
89 Reputatie
10 handleidingen geschreven
Cal Poly, Team 34-55, Forte Spring 2010 Lid van Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,939
