Ga door naar hoofdinhoud
LG VX8350 Repair Keypad Removal
Wat je nodig hebt
  1. LG VX8350 Repair Keypad Removal, Battery: stap 1, afbeelding 1 van 2 LG VX8350 Repair Keypad Removal, Battery: stap 1, afbeelding 2 van 2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. LG VX8350 Repair Keypad Removal: stap 2, afbeelding 1 van 2 LG VX8350 Repair Keypad Removal: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. LG VX8350 Repair Keypad Removal, Circuit Board Housing: stap 3, afbeelding 1 van 3 LG VX8350 Repair Keypad Removal, Circuit Board Housing: stap 3, afbeelding 2 van 3 LG VX8350 Repair Keypad Removal, Circuit Board Housing: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. LG VX8350 Repair Keypad Removal: stap 4, afbeelding 1 van 2 LG VX8350 Repair Keypad Removal: stap 4, afbeelding 2 van 2
    • Lift the back cover starting at the bottom of the phone.
  5. LG VX8350 Repair Keypad Removal: stap 5, afbeelding 1 van 2 LG VX8350 Repair Keypad Removal: stap 5, afbeelding 2 van 2
    • Remove the back cover completely from the phone.
  6. LG VX8350 Repair Keypad Removal, Circuit Board: stap 6, afbeelding 1 van 1
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  7. LG VX8350 Repair Keypad Removal: stap 7, afbeelding 1 van 2 LG VX8350 Repair Keypad Removal: stap 7, afbeelding 2 van 2
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
  8. LG VX8350 Repair Keypad Removal, Keypad: stap 8, afbeelding 1 van 2 LG VX8350 Repair Keypad Removal, Keypad: stap 8, afbeelding 2 van 2
    • Lift the keyboard and remove it from the phone.
Conclusie
James Brandon
207 Reputatie
2 handleidingen geschreven
Clemson, Team 14-7, Benson Fall 2013 Lid van Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 430
