Ga door naar hoofdinhoud
LG VX8300 Antenna Replacement
Wat je nodig hebt
  1. LG VX8300 Antenna Replacement, Disassembling LG VX8300 Body: stap 1, afbeelding 1 van 3 LG VX8300 Antenna Replacement, Disassembling LG VX8300 Body: stap 1, afbeelding 2 van 3 LG VX8300 Antenna Replacement, Disassembling LG VX8300 Body: stap 1, afbeelding 3 van 3
    • Power off the device by holding down the red button labeled PWR.
    • Be sure that the phone is powered off before touching the battery to avoid danger.
    • Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
  2. LG VX8300 Antenna Replacement: stap 2, afbeelding 1 van 2 LG VX8300 Antenna Replacement: stap 2, afbeelding 2 van 2
    • Place your finger into the semicircle gap on top of the battery.
    • Apply force downward and out, so the battery pops out of the phone.
  3. LG VX8300 Antenna Replacement: stap 3, afbeelding 1 van 3 LG VX8300 Antenna Replacement: stap 3, afbeelding 2 van 3 LG VX8300 Antenna Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Locate the two rubber pads covering the screws at the top of the phone near the hinge.
    • Use tweezers to lift and remove the rubber pads.
  4. LG VX8300 Antenna Replacement: stap 4, afbeelding 1 van 2 LG VX8300 Antenna Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove all four 3mm screws from the back of the phone.
  5. LG VX8300 Antenna Replacement: stap 5, afbeelding 1 van 2 LG VX8300 Antenna Replacement: stap 5, afbeelding 2 van 2
    • Use your fingers to gently separate the front plate from the phone. You may need to slide a plastic opening tool along the crevice between the faces to separate it more easily.
    • Remove the casing after it has been detached. The logic board is now fully accessible.
    • Once the body case is removed, the volume and camera buttons move freely. Ensure all loose pieces remain accounted for.
  6. LG VX8300 Antenna Replacement, Antenna Replacement: stap 6, afbeelding 1 van 3 LG VX8300 Antenna Replacement, Antenna Replacement: stap 6, afbeelding 2 van 3 LG VX8300 Antenna Replacement, Antenna Replacement: stap 6, afbeelding 3 van 3
    • Place the phone in front of you. With the antenna in the top right corner, and the opened back panel facing up.
    • Use a Phillips #00 Screwdriver to remove the single 2mm x 3mm screw. Found on the gold band, just underneath the antenna.
  7. LG VX8300 Antenna Replacement: stap 7, afbeelding 1 van 1
    • Remove the antenna by pulling it straight and out of its housing.
    • The phone is now ready for a new antenna.
  8. LG VX8300 Antenna Replacement: stap 8, afbeelding 1 van 1
    • Insert the new antenna by pushing it straight into its housing on the phone.
  9. LG VX8300 Antenna Replacement: stap 9, afbeelding 1 van 1
    • Place the 2mm x 3mm screw back onto the gold band, just underneath the antenna. Use a Phillips #00 Screwdriver to replace the screw that you removed in step one.
Conclusie
You have now successfully completed the antenna replacement for an LG VX8300 flip phone.
nvalm
448 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 3-7, Duarte Spring 2015 Lid van UMass Dartmouth, Team 3-7, Duarte Spring 2015
UMASSD-DUARTE-S15S3G7
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 303
