Ga door naar hoofdinhoud
LG VX7000 Motherboard Replacement
Wat je nodig hebt
  1. LG VX7000 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the phone, screen side down, in your palm.
    • Slide the grey button towards the top of the phone.
  2. LG VX7000 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
  3. LG VX7000 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the Phillips #00 and remove the four screws on the lower backside of the phone.
    • Remove the three rubber screw covers with tweezers and then the three screws underneath using a Phillips #00 screwdriver.
  4. LG VX7000 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Detach the outer casing from the back of the phone.
    • There will be a significant amount of resistance to detaching the back casing.
  5. LG VX7000 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Unsnap the gold rectangular connector and silver square connector from the motherboard.
  6. LG VX7000 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the motherboard. Do not remove other components.
    • Insert the new motherboard with the white side facing down.
    • Make sure the side buttons on motherboard are correctly aligned to avoid future complications.
Conclusie
Nichole Shaw
1 Reputatie
7 handleidingen geschreven
Cal Poly, Team 18-75, Johann Spring 2010 Lid van Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,341
