Ga door naar hoofdinhoud
LG VX7000 Keypad Replacement
Wat je nodig hebt
  1. LG VX7000 Keypad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the phone, screen side down, in your palm.
    • Slide the grey button towards the top of the phone.
  2. LG VX7000 Keypad Replacement: stap 2, afbeelding 1 van 1
    • With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
  3. LG VX7000 Keypad Replacement, Keypad: stap 3, afbeelding 1 van 1
    • Locate four screws underneath of the battery.
    • Remove screws by turning counter clockwise with screwdriver until they pop out.
  4. LG VX7000 Keypad Replacement: stap 4, afbeelding 1 van 1
    • Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
    • Note: There will be a significant amount of resistance.
  5. LG VX7000 Keypad Replacement: stap 5, afbeelding 1 van 1
    • Lift up logic board without completely removing from phone.
    • Remove entire keypad from beneath the logic board.
  6. LG VX7000 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Insert replacement keypad with buttons aligned in proper holes.
Conclusie
Nichole Shaw
1 Reputatie
7 handleidingen geschreven
Cal Poly, Team 18-75, Johann Spring 2010 Lid van Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 45
Altijd: 1,206
