Ga door naar hoofdinhoud
LG VX7000 External LCD Display Replacement
Wat je nodig hebt
  1. LG VX7000 External LCD Display Replacement, External LCD Display: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
    • NOTE: There will be a total of four rubber screw covers removed.
    • Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
    • NOTE: The screws can not be completely removed from their holes.
  2. LG VX7000 External LCD Display Replacement: stap 2, afbeelding 1 van 1
    • Using the "iPod Opening Tool", separate the faceplate from the front of the phone.
    • NOTE: There will be a significant amount of resistance when separating the faceplate from the phone.
    • Align the new faceplate in the place of the previously cracked faceplate, and press the new faceplate onto the phone.
Conclusie
Nichole Shaw
1 Reputatie
7 handleidingen geschreven
Cal Poly, Team 18-75, Johann Spring 2010 Lid van Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Leden
14 handleidingen geschreven
1Gids Commentaar
My phone turns on but the screen is black I think because one side of the phone the is broken where you flip it open it opens but you just can't see the screen
chayp62 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,808
