Ga door naar hoofdinhoud
LG VX6100 Keypad Replacement
Wat je nodig hebt
  1. LG VX6100 Keypad Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Keypad Replacement: stap 2, afbeelding 1 van 1
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Keypad Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Keypad Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Keypad Replacement: stap 5, afbeelding 1 van 2 LG VX6100 Keypad Replacement: stap 5, afbeelding 2 van 2
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
  6. LG VX6100 Keypad Replacement, Keypad: stap 6, afbeelding 1 van 1
    • Lift the bottom of the logic board out of the case.
    • Make sure not to lift the top of the logic board, since it is still connected to the backcase of the phone.
  7. LG VX6100 Keypad Replacement: stap 7, afbeelding 1 van 1
    • Gently lift up on any edge of the white keypad to remove it from the phone case.
Conclusie
Teal
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-39, Regan Spring 2012 Lid van Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 555
