Inleiding
The screens for the LG VX5600 come together as a single unit inside the phone therefore to replace one you will be replacing the other.
Wat je nodig hebt
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Use one hand to grasp the phone and prop the inner grey casing up.
Unscrew the two 3.0-mm Phillips #000 screws located in the upper left and right hand corners.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
just swapped screens Perfect. step 5 is harder than it look but take time and go easy, I used a 1/8 in blade screwdriver.
