Ga door naar hoofdinhoud
LG VX5500 Screen Replacement
Wat je nodig hebt
  1. LG VX5500 Screen Replacement, Battery: stap 1, afbeelding 1 van 3 LG VX5500 Screen Replacement, Battery: stap 1, afbeelding 2 van 3 LG VX5500 Screen Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Screen Replacement, Screen: stap 2, afbeelding 1 van 2 LG VX5500 Screen Replacement, Screen: stap 2, afbeelding 2 van 2
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  3. LG VX5500 Screen Replacement: stap 3, afbeelding 1 van 2 LG VX5500 Screen Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  4. LG VX5500 Screen Replacement: stap 4, afbeelding 1 van 3 LG VX5500 Screen Replacement: stap 4, afbeelding 2 van 3 LG VX5500 Screen Replacement: stap 4, afbeelding 3 van 3
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  5. LG VX5500 Screen Replacement: stap 5, afbeelding 1 van 2 LG VX5500 Screen Replacement: stap 5, afbeelding 2 van 2
    • Use the tweezers to lift the display adapter off the screen component.
  6. LG VX5500 Screen Replacement: stap 6, afbeelding 1 van 2 LG VX5500 Screen Replacement: stap 6, afbeelding 2 van 2
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  7. LG VX5500 Screen Replacement: stap 7, afbeelding 1 van 2 LG VX5500 Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove the earpiece by lifting it out of the phone casing using tweezers.
    • The earpiece is adhered to the phone casing so it will take a small amount of force to remove it.
  8. LG VX5500 Screen Replacement: stap 8, afbeelding 1 van 2 LG VX5500 Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove the vibration motor by lifting it out of the phone casing using tweezers.
    • The motor is adhered to the phone casing so it will take a small amount of force to remove it.
  9. LG VX5500 Screen Replacement: stap 9, afbeelding 1 van 1
    • Lift the screen components out of the phone.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Henry
181 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-33, Maness Spring 2012 Lid van Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Leden
10 handleidingen geschreven
2 opmerkingen
I have it apart know need to learn to solder!
Andy Fowler - Antwoord
where can i purchase a replacement screen?
kalea dean - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 3,781
