Ga door naar hoofdinhoud
LG VX5500 Mother Board Replacement
Wat je nodig hebt
  1. LG VX5500 Mother Board Replacement, Battery: stap 1, afbeelding 1 van 3 LG VX5500 Mother Board Replacement, Battery: stap 1, afbeelding 2 van 3 LG VX5500 Mother Board Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Mother Board Replacement, Mother Board: stap 2, afbeelding 1 van 2 LG VX5500 Mother Board Replacement, Mother Board: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Mother Board Replacement: stap 3, afbeelding 1 van 3 LG VX5500 Mother Board Replacement: stap 3, afbeelding 2 van 3 LG VX5500 Mother Board Replacement: stap 3, afbeelding 3 van 3
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Mother Board Replacement: stap 4, afbeelding 1 van 2 LG VX5500 Mother Board Replacement: stap 4, afbeelding 2 van 2
    • Peel back the sticker with tweezers and hold it back with your finger.
    • Use the tweezers to lift the display adapter off the logic board.
  5. LG VX5500 Mother Board Replacement: stap 5, afbeelding 1 van 2 LG VX5500 Mother Board Replacement: stap 5, afbeelding 2 van 2
    • Lift the mother board out of the phone casing.
    • The keyboard can be easily removed once the mother board is out of the phone.
Conclusie
Henry
181 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-33, Maness Spring 2012 Lid van Cal Poly, Team 7-33, Maness Spring 2012
CPSU-MANESS-S12S7G33
4 Leden
10 handleidingen geschreven
2 opmerkingen
You guys are great!
Kurt Beske - Antwoord
So what do you do with the mother board then?
Erik Sodders - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 2,152
