Ga door naar hoofdinhoud
LG VX5300 outer LCD screen replacement
Wat je nodig hebt
  1. LG VX5300 outer LCD screen replacement, Front LCD Screen: stap 1, afbeelding 1 van 1
    • Remove the rubber stoppers from the four corners of the front screen.
  2. LG VX5300 outer LCD screen replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips screwdriver, carefully remove all four screws.
  3. LG VX5300 outer LCD screen replacement: stap 3, afbeelding 1 van 2 LG VX5300 outer LCD screen replacement: stap 3, afbeelding 2 van 2
    • To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
  4. LG VX5300 outer LCD screen replacement, LCD Screen: stap 4, afbeelding 1 van 2 LG VX5300 outer LCD screen replacement, LCD Screen: stap 4, afbeelding 2 van 2
    • Carefully lift off the black frame around the LCD screen and set it aside.
  5. LG VX5300 outer LCD screen replacement: stap 5, afbeelding 1 van 1
    • Lift the speaker out by using tweezers.
    • Next, lift the battery out using the tweezers.
  6. LG VX5300 outer LCD screen replacement: stap 6, afbeelding 1 van 1
    • Using tweezers, carefully disconnect the orange ribbon from the computer chip.
  7. LG VX5300 outer LCD screen replacement: stap 7, afbeelding 1 van 1
    • Remove the LCD screen and replace with a new one.
    • Finally, replace the battery and the speaker.
Conclusie
Ashley
13 Reputatie
3 handleidingen geschreven
Ohio State, Team 1-1, Buehl Spring 2013 Lid van Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Leden
4 handleidingen geschreven
Één opmerking
Thanks for the instructions. By chance, do you know how to replace the motherboard? Where is the mother board
Sula Tremaine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 12
Altijd: 498
