Ga door naar hoofdinhoud
LG VX5300 Keypad Replacement
Wat je nodig hebt
  1. LG VX5300 Keypad Replacement, Disassembling Back Cover: stap 1, afbeelding 1 van 3 LG VX5300 Keypad Replacement, Disassembling Back Cover: stap 1, afbeelding 2 van 3 LG VX5300 Keypad Replacement, Disassembling Back Cover: stap 1, afbeelding 3 van 3
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. LG VX5300 Keypad Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  3. LG VX5300 Keypad Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic opening tool, carefully lift the back cover off.
  4. LG VX5300 Keypad Replacement, Keypad: stap 4, afbeelding 1 van 2 LG VX5300 Keypad Replacement, Keypad: stap 4, afbeelding 2 van 2
    • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
    • Look to the following photo for the location of the two sensor bars.
    • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
  5. LG VX5300 Keypad Replacement: stap 5, afbeelding 1 van 2 LG VX5300 Keypad Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the keypad and replace with the new keypad.
    • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  6. LG VX5300 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Carefully set the computer chip back in place.
  7. LG VX5300 Keypad Replacement: stap 7, afbeelding 1 van 2 LG VX5300 Keypad Replacement: stap 7, afbeelding 2 van 2
    • Place the back cover back on and secure it with the screws.
  8. LG VX5300 Keypad Replacement: stap 8, afbeelding 1 van 2 LG VX5300 Keypad Replacement: stap 8, afbeelding 2 van 2
    • Insert the battery.
    • Slide the back cover on the phone.
Eindstreep
Ashley
13 Reputatie
3 handleidingen geschreven
Ohio State, Team 1-1, Buehl Spring 2013 Lid van Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 575
