Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If the LCD screen on your LG VX5200 is damaged or is non-functional, use this guide to replace the LCD screen.
The LCD screen is the visual display of the device. If the screen has physical damage, is not displaying anything, or is illegible, the screen may need to be replaced.
Before committing to replacing the LCD screen, reset your phone and see if the LCD screen is displaying properly.
Before disassembly, make sure you completely turn off the phone.
  1. Turn the phone on its back. Turn the phone on its back.
    • Turn the phone on its back.
  2. Orient the phone as shown. Remove the battery cover by pushing upward with your thumb.
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. Place your fingernail at the top of the battery and pry the battery out towards you. Place your fingernail at the top of the battery and pry the battery out towards you.
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. Flip the phone open. Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin. Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  6. Insert the plastic opening tool in the seam of the top portion of the flip phone. Gently pry the seam open. Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
    • Insert the plastic opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  7. Close the flip phone. Hold the base of the phone and gently remove the faceplate. Place the phone and the faceplate on a clean, flat surface.
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  8. Try not to move the thin component wires as they will bend and break very easily. Try not to move the thin component wires as they will bend and break very easily.
    • Try not to move the thin component wires as they will bend and break very easily.
  9. Remove the white stopper from the camera light located above the gold connector. Lift the gold connector up with your finger to detach it. Lift the gold connector up with your finger to detach it.
    • Remove the white stopper from the camera light located above the gold connector.
    • Lift the gold connector up with your finger to detach it.
  10. Gently lift out the speaker with your fingertip.
    • Gently lift out the speaker with your fingertip.
  11. Gently lift out the square LCD assembly being careful with the attached vibrator wires. Gently remove the vibrator with tweezers. The LCD screen, speaker and vibrator will separate from the phone as a single unit.
    • Gently lift out the square LCD assembly being careful with the attached vibrator wires.
    • Gently remove the vibrator with tweezers.
    • The LCD screen, speaker and vibrator will separate from the phone as a single unit.
  12. Place phone body and LCD screen on a clean, lint-free surface. Place phone body and LCD screen on a clean, lint-free surface.
    • Place phone body and LCD screen on a clean, lint-free surface.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Douglas Blaalid
282 Reputatie
8 handleidingen geschreven
Cal Poly, Team 4-13, Forte Winter 2010 Lid van Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Leden
15 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 3,713
