Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
A guide to removing the LCD screen.
Wat je nodig hebt
Flip the phone open.
Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
The speaker is the dark gray, larger circular-shaped piece to the right of the battery. Attached to it are the four thin wires.
The vibrator wires are thinner and even more fragile.
3 andere personen hebben deze handleiding voltooid.
