Ga door naar hoofdinhoud
LG VX5200 Antenna Replacement
Wat je nodig hebt
  1. LG VX5200 Antenna Replacement, Battery: stap 1, afbeelding 1 van 2 LG VX5200 Antenna Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the phone on its back.
  2. LG VX5200 Antenna Replacement: stap 2, afbeelding 1 van 2 LG VX5200 Antenna Replacement: stap 2, afbeelding 2 van 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Antenna Replacement: stap 3, afbeelding 1 van 2 LG VX5200 Antenna Replacement: stap 3, afbeelding 2 van 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Antenna Replacement, LG VX5200 Rear Body Panel Disassembly: stap 4, afbeelding 1 van 1
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 Antenna Replacement: stap 5, afbeelding 1 van 3 LG VX5200 Antenna Replacement: stap 5, afbeelding 2 van 3 LG VX5200 Antenna Replacement: stap 5, afbeelding 3 van 3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 Antenna Replacement: stap 6, afbeelding 1 van 3 LG VX5200 Antenna Replacement: stap 6, afbeelding 2 van 3 LG VX5200 Antenna Replacement: stap 6, afbeelding 3 van 3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 Antenna Replacement: stap 7, afbeelding 1 van 1
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 Antenna Replacement, Antenna: stap 8, afbeelding 1 van 1
    • Locate the screw and copper fixture that hold the antenna in place.
    • Remove the screw from the device using a Philips #00 screwdriver.
  9. LG VX5200 Antenna Replacement: stap 9, afbeelding 1 van 2 LG VX5200 Antenna Replacement: stap 9, afbeelding 2 van 2
    • Remove the copper fixture after it has been unscrewed.
  10. LG VX5200 Antenna Replacement: stap 10, afbeelding 1 van 2 LG VX5200 Antenna Replacement: stap 10, afbeelding 2 van 2
Conclusie
Douglas Blaalid
282 Reputatie
8 handleidingen geschreven
Cal Poly, Team 4-13, Forte Winter 2010 Lid van Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,474
