Inleiding
Replacing the LCD screen.
  1. Turn the closed phone so that the back panel is facing you.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. Now just lift up on the battery and remove it from the phone. Now just lift up on the battery and remove it from the phone.
    • Now just lift up on the battery and remove it from the phone.
  3. Remove 4 rubber grommets using the Spudger.
    • Remove 4 rubber grommets using the Spudger.
  4. Remove 4 screws using the Phillips #00 Screwdriver.
    • Remove 4 screws using the Phillips #00 Screwdriver.
  5. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  6. Carefully pry off outer cover using iPod Opening Tool. Carefully pry off outer cover using iPod Opening Tool. Carefully pry off outer cover using iPod Opening Tool.
    • Carefully pry off outer cover using iPod Opening Tool.
  7. Remove speaker using the Spudger. Remove speaker using the Spudger.
    • Remove speaker using the Spudger.
  8. Remove vibrator using the Spudger. Remove vibrator using the Spudger.
    • Remove vibrator using the Spudger.
  9. Lift up LCD display using iPod Opening Tool. Lift up LCD display using iPod Opening Tool.
    • Lift up LCD display using iPod Opening Tool.
  10. DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • De-solder solder joint using Soldering Iron.
  11. Pry off ribbon cable using iPod Opening Tool. Pry off ribbon cable using iPod Opening Tool.
    • Pry off ribbon cable using iPod Opening Tool.
Conclusie
David Foster
1 Reputatie
8 handleidingen geschreven
Cal Poly, Team 25-88, Amido Spring 2010 Lid van Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Leden
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 2,204
