Ga door naar hoofdinhoud
LG V10 Battery Replacement
Wat je nodig hebt
  1. LG V10 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. LG V10 Battery Replacement: stap 2, afbeelding 1 van 2 LG V10 Battery Replacement: stap 2, afbeelding 2 van 2
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
Conclusie
After replacing the old battery with a new one, reattach the back cover and press down on all sides to make sure it's properly reattached.
3 andere personen hebben deze handleiding voltooid.
Nikolai Lesh
344 Reputatie
1 Handleiding geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.506 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 2,954
