Inleiding
To replace the dryer cord for the LG TrueSteam you will simply need a Phillips #0 screwdriver. It will fit all screws that you will be taking out today. If not done correctly there could be some electrical hazards. Make sure to pull out the dryer from the wall to ensure maximum space for you to work with. Insure that you have plenty of light, and steady hands to complete this fix. The total list of Phillips head screws are: (2.2mm)x3, (3.2mm)x2, (6mm)x 2.
Wat je nodig hebt
To replace the dryer cord for the LG PureSteam you will simply need a #0 Phillips screwdriver. If not done correctly there could be some electrical hazards. Make sure to pull out the dryer from the wall to ensure maximum space for you to work with. Insure that you plenty of light, and steady hands to complete this fix.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
The spare screw note was a life saver. Didn't even notice that was there and was scrambling to find a replacement before I found this guide.
I have an existing manufacturer power cord that has no color coded wires. They’re all gray and homogenous. Can’t distinguish one from the other. What do I do? I uninstalled this cord thinking that I needed to replace it with a different cord but found out that it would actually work so I reinstalled it not knowing that it required a specific color code installation.
