Ga door naar hoofdinhoud
LG Tone Pro HBS750 Magnet Replacement
Wat je nodig hebt
  1. LG Tone Pro HBS750 Magnet Replacement, Magnet: stap 1, afbeelding 1 van 2 LG Tone Pro HBS750 Magnet Replacement, Magnet: stap 1, afbeelding 2 van 2
    • Find the side of the device with the defective magnet. Remove the rubber piece on the underside of the device that protects the screw.
  2. LG Tone Pro HBS750 Magnet Replacement: stap 2, afbeelding 1 van 1
    • Remove the small screw from the underside of the device and place it aside.
  3. LG Tone Pro HBS750 Magnet Replacement: stap 3, afbeelding 1 van 1
    • Place a small prying tool in between the two cases and slowly push the two apart. Be sure not to force the case apart, as it may snap in the process.
  4. LG Tone Pro HBS750 Magnet Replacement: stap 4, afbeelding 1 van 1
    • Once the case is open, the small magnet is now visible and can be replaced.
  5. LG Tone Pro HBS750 Magnet Replacement: stap 5, afbeelding 1 van 1
    • Once the new magnet is in place, the casing can be pushed back together.
  6. LG Tone Pro HBS750 Magnet Replacement: stap 6, afbeelding 1 van 1
    • The small screw that was taken out at the beginning can be screwed back into the device.
  7. LG Tone Pro HBS750 Magnet Replacement: stap 7, afbeelding 1 van 1
    • Push the small rubber piece back into place over the screw.
Eindstreep
6 andere personen hebben deze handleiding voltooid.
Andrew Oglesby
246 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-2, Shastany Spring 2015 Lid van UMass Dartmouth, Team 2-2, Shastany Spring 2015
UMASSD-SHASTANY-S15S2G2
3 Leden
2 handleidingen geschreven
Één opmerking
Thanks for your instruction. Tell me please what is the thickness of the ear cords is it possible to connect them back after it was teared off? I want to buy broken on the ebay and fix it but I can't understand if it possible to fix it without looking on the cords.
macosrus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 32
Altijd: 3,035
