Ga door naar hoofdinhoud
LG Tone Infinim HBS-910 Battery Replacement
Wat je nodig hebt
  1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: stap 1, afbeelding 1 van 3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: stap 1, afbeelding 2 van 3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: stap 1, afbeelding 3 van 3
    • Battery is on right side of headset.
    • First remove rubber cover on the right side of the headset to uncover the hidden screw.
    • Remove screw using Philips PH00 screwdriver.
  2. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: stap 2, afbeelding 1 van 2 LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: stap 2, afbeelding 2 van 2
    • Use a guitar pick or any opening tool to pry open the right side.
  3. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: stap 3, afbeelding 1 van 3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: stap 3, afbeelding 2 van 3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: stap 3, afbeelding 3 van 3
    • Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
    • Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
    • Once the speaker back housing is lifted, you will see the screw.
    • Remove the screw and the whole right side will be disassembled.
    Search f9r replacement rechargeable hearing ampliflire batteries
    wayneharnon74graduate - Antwoord
  4. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: stap 4, afbeelding 1 van 3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: stap 4, afbeelding 2 van 3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: stap 4, afbeelding 3 van 3
    • Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
    • Remember the red wire is positive(+) and the black wire is negative(-).
Conclusie
13 andere personen hebben deze handleiding voltooid.
Faizan Naveed
3.294 Reputatie
8 handleidingen geschreven
Mobile Device Repair Factory Lid van Mobile Device Repair Factory
Business
1 Lid
16 handleidingen geschreven
2 opmerkingen
Battery model and amps
honda kung - Antwoord
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
Rafael Zerbini - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 11,261
