Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Make sure your phone is turned off.
Wat je nodig hebt
Pry open the back cover by using a fingernail or a plastic opening tool.
Remove the three screws from the bottom of the phone. These three screws are located on the speaker itself:
Two 5.5 mm Phillips #00 screws
One 4 mm Phillips #00 screw
There is a notch located at the bottom of the speaker. Insert a fingernail in to the notch and pull up.
