Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Before we begin disassembling your LG device, make sure your phone is turned off, make sure you have .the back cover and the battery detached to properly access the sim card board.
Wat je nodig hebt
Pry open the back cover by using a fingernail or a plastic opening tool.
Remove the three Philips #00 screws from the bottom of the phone.
Two 5.5 mm screws
One 4 mm screw
Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
Utilize a spudger or plastic opening tool, and very gently disconnect the ribbon cable in two different areas, attached to the black micro SIM card board.
Carefully pry the board up to detach it from its lock bezel socket.
Make sure to pry the little tab connected to the camera unit as well.
Één andere persoon heeft deze handleiding voltooid.
