Ga door naar hoofdinhoud
LG Thrill 4G Phone Buttons Replacement
Wat je nodig hebt
  1. LG Thrill 4G Phone Buttons Replacement, Back Cover Removal: stap 1, afbeelding 1 van 2 LG Thrill 4G Phone Buttons Replacement, Back Cover Removal: stap 1, afbeelding 2 van 2
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G Phone Buttons Replacement, Battery Removal: stap 2, afbeelding 1 van 2 LG Thrill 4G Phone Buttons Replacement, Battery Removal: stap 2, afbeelding 2 van 2
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G Phone Buttons Replacement, Screw Removal: stap 3, afbeelding 1 van 1
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G Phone Buttons Replacement, Speaker Removal: stap 4, afbeelding 1 van 2 LG Thrill 4G Phone Buttons Replacement, Speaker Removal: stap 4, afbeelding 2 van 2
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G Phone Buttons Replacement, Buttons: stap 5, afbeelding 1 van 1
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G Phone Buttons Replacement: stap 6, afbeelding 1 van 3 LG Thrill 4G Phone Buttons Replacement: stap 6, afbeelding 2 van 3 LG Thrill 4G Phone Buttons Replacement: stap 6, afbeelding 3 van 3
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G Phone Buttons Replacement: stap 7, afbeelding 1 van 1
    • Remove the six Phillips #00 screws within the mid-cover bezel.
Conclusie
Kenny Richmond
260 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-6, Blackwell Winter 2015 Lid van USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 549
