Ga door naar hoofdinhoud
LG TV 49SJ8000 - WiFi module disassembly
Wat je nodig hebt
  1. LG TV 49SJ8000 - WiFi module disassembly, LG TV 49SJ8000 - WiFi module disassembly: stap 1, afbeelding 1 van 1
    • Place the display on a soft surface in order to help prevent scratches and/or breaking the display.
    • Remove the 4 Phillips screws that hold the stand in place (if installed).
    • Remove all screws from the rear panel.
    • There are two screws near to the input and output connectors.
    • On the lower part of the TV (next to the speakers) there are two additional screws that need to be removed.
  2. LG TV 49SJ8000 - WiFi module disassembly: stap 2, afbeelding 1 van 1
    • With the panel removed, it's possible to visualize the boards and its connections.
    • To the left, there is the power supply, which supplies power to the TV.
    • To the right, there is the logic board.
    • On the lower section you can locate both speakers.
    • Between both speakers you can find the Wi-Fi and Bluetooth module.
  3. LG TV 49SJ8000 - WiFi module disassembly: stap 3, afbeelding 1 van 2 LG TV 49SJ8000 - WiFi module disassembly: stap 3, afbeelding 2 van 2
    • To remove the Wi-Fi and Bluetooth module, there is only one screw holding the entirety of the structure.
  4. LG TV 49SJ8000 - WiFi module disassembly: stap 4, afbeelding 1 van 2 LG TV 49SJ8000 - WiFi module disassembly: stap 4, afbeelding 2 van 2
    • Wi-Fi module removed.
    • If your TV shows the message Device Connected/Device Disconnected, Wi-Fi not working or Magic remote not working, it's possible that there is a bad connection on the module.
    • Remove the flex cables carefully and install them once again.
    • In order to remove the flex cable, there is a little tab that needs to be lifted.
Conclusie
To reassemble your device, follow this instructions in inverse order.
8 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
pt en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Diogo Cordova
301 Reputatie
1 Handleiding geschreven
3Gids Commentaar
Excelente dica e tutorial! Executei os passos aqui e minha TV voltou a funcionar a conexão de Internet via wifi. Eu usava somente o cabo. O controle magic e os app não apresentam mais travamentos.
Edgar Conrado Pereira - Antwoord
Obrigado. O chato é que normalmente o problema volta após algum tempo. A solução definitiva por aqui foi deixar sem o módulo, abandonado o uso do Wi-Fi e sem o controle Magic.
Diogo Cordova -
Excellent and works well !! Thank you and I approve it works for SK8100PLA
AAGAYER - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 76
Afgelopen 30 dagen: 414
Altijd: 13,905
