Ga door naar hoofdinhoud
LG TP 1100 Microphone Replacement
Wat je nodig hebt
  1. LG TP 1100 Microphone Replacement, Microphone: stap 1, afbeelding 1 van 1
    • Hold antenna between your fingers and unscrew in a counterclockwise direction.
  2. LG TP 1100 Microphone Replacement: stap 2, afbeelding 1 van 1
    • You will remove antenna by pulling it in an upward motion away from the socket.
  3. LG TP 1100 Microphone Replacement: stap 3, afbeelding 1 van 1
    • Turn phone so that the back is facing you.
  4. LG TP 1100 Microphone Replacement: stap 4, afbeelding 1 van 1
    • Use your thumb to pull the tab in an upward motion to release the battery.
  5. LG TP 1100 Microphone Replacement: stap 5, afbeelding 1 van 1
    • Hold phone securely in one hand and pull the battery away from the phone with your other hand.
  6. LG TP 1100 Microphone Replacement: stap 6, afbeelding 1 van 1
    • Use your screwdriver to unscrew the four screws from the back plate.
  7. LG TP 1100 Microphone Replacement: stap 7, afbeelding 1 van 1
    • Turn phone to the side as indicated in the picture.
  8. LG TP 1100 Microphone Replacement: stap 8, afbeelding 1 van 1
    • Remove the back cover that you just unscrewed and set aside.
  9. LG TP 1100 Microphone Replacement: stap 9, afbeelding 1 van 1
    • Open the remaining parts like a book but do not separate the two pieces.
    • Do not tear the tape connecting the two pieces.
  10. LG TP 1100 Microphone Replacement: stap 10, afbeelding 1 van 2 LG TP 1100 Microphone Replacement: stap 10, afbeelding 2 van 2
    • Rotate the phone so that the circuit board is in the palm of your hand and the part connected with tape hangs behind.
    • Use your opening tool to pry the circuit board from the front cover. Do not let the number pad to fall out.
  11. LG TP 1100 Microphone Replacement: stap 11, afbeelding 1 van 1
    • To remove the microphone, insert your opening tool under microphone and push upward to pry microphone away from the front cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnny Inlow
19 Reputatie
3 handleidingen geschreven
Cal Poly, Team 27-91, Amido Spring 2010 Lid van Cal Poly, Team 27-91, Amido Spring 2010
CPSU-AMIDO-S10S27G91
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,303
