Inleiding
This guide will walk you through the steps of removing the midframe of your LG Sunrise.
Wat je nodig hebt
Stap 5 Lower Back Plastic Piece
Voorzichtig: stappen 5-6 komen van een handleiding die in bewerking is.
You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
